OsosGratis
Feb 18, 2021Tutor
AC3200 WIFI Connected - Not able to access all apps programs
Nighthawk X6 AC3200 WIFI When connected to wifi, none of the phones or computers in my house are working properly. Some internet connected apps work fine, but others give me issues. I cannot brow...
- Feb 18, 2021
The Ubee is a modem router combo device. do you have it in passthrough/modem only mode?
or the R8000 in access point mode?
Or the R8000's ip address entered into the ubee's dmz?
otherwise you're in a double nat .
Feb 18, 2021Guru - Experienced User
What router is it? AC3200 is a speed, not a model.
What firmware is on it?
What modem/gateway is it connected to?
- OsosGratisFeb 18, 2021Tutor
Sorry!
Model R8000
Firware Version 1.0.4.68
The modem is a UBEE Model UBC1301
- plemansFeb 18, 2021Guru - Experienced User
Nailed it - fully operational. I had the wifi turned off at the modem but didn't have the access point or passthrough set up properly.
