OsosGratis
Feb 18, 2021Tutor
AC3200 WIFI Connected - Not able to access all apps programs
Nighthawk X6 AC3200 WIFI When connected to wifi, none of the phones or computers in my house are working properly. Some internet connected apps work fine, but others give me issues. I cannot brow...
- Feb 18, 2021
The Ubee is a modem router combo device. do you have it in passthrough/modem only mode?
or the R8000 in access point mode?
Or the R8000's ip address entered into the ubee's dmz?
otherwise you're in a double nat .
OsosGratis
Feb 18, 2021Tutor
Sorry!
Model R8000
Firware Version 1.0.4.68
The modem is a UBEE Model UBC1301
Feb 18, 2021Guru - Experienced User
- OsosGratisFeb 18, 2021Tutor
Nailed it - fully operational. I had the wifi turned off at the modem but didn't have the access point or passthrough set up properly.
- michaelkenwardFeb 19, 2021Guru - Experienced User
OsosGratis wrote:
I had the wifi turned off at the modem ....
You are not the first, and won't be the last, to think that turning off the wifi put a modem/router into "bridge" mode. That's why "what is your modem?" is one of the first questions asked here.
It is good to have yet another report that this fixes problems for someone. Thanks for the report back.
