ronsmith47
Jun 26, 2020Aspirant
ac322 - smart connect
I am trying to enable smart connect on my AC3200 nighthawk router. In the manual it is stated and pictured that the smart connect is selected on each of the 5 ghz band. My display is different on m...
- Jun 26, 2020
You can just disable smart connect.
then setup your own ssid's for the 3x bands.
ronsmith47
the problem there is that I have a couple of low spped devices that can't smart connect and need the seperate ssid for the low speed band
Jun 26, 2020Guru - Experienced User
