V-Rex1
Oct 16, 2021Aspirant
AC4000 TRI BAND X6S Wireless devices won't connect and can't be added to my network since new modem
Hi, I recently had to buy a new modem for my internet service (Xfinity) because my old one went obsolete. I purchased a Nighthawk CM 2050V to replace my old CM1000. Xfinity added the device no prob...
Oct 17, 2021Guru - Experienced User
Try this.
power off the modem and the router and disconnect everything from both. Even the coax from the modem.
Wait a couple minutes.
connect coax back to the modem and power it on.
give it a couple minutes to fully boot.
connect the lan cable from it to the router.
Then power the router on and give it a couple minutes.
does it work?
If not, try that same procedure but factory reset the router by pushing and holding reset for 7-15 seconds.
What firmware is on the router?
What was the prior modem from xfinity?
