spiderman1
May 13, 2016Guide
AC5300 (Fibre Modem)
Hi Fellows, I was wondering if the AC5300 router is vdsl capable? If not, which wifi router should I buy that has a fibre optics modem built-in? On the other hand, is there a standalone fibre op...
- May 16, 2016
Hello spiderman1
Welcome to the community!
Your modem should support the fiber optic connection then you connect to the AC5300 (R8500) router.
However, if you're looking for a modem router that has a fiber optic modem built-in, NETGEAR does not have any device that would meet that requirement.
We only have Cable and VDSL gateways.
ElaineM
May 16, 2016NETGEAR Employee Retired
Hello spiderman1
