Axeldook
Oct 28, 2015Aspirant
AC5300 Nighthawk X8 Smart WiFi Router R8500 uk release date
Hi, Does anyone know when this router will be released in the UK please. thanks
- Nov 05, 2015
Possible release will be mid-December of this year.
Babylon5
Oct 28, 2015NETGEAR Employee Retired
Someone may come up with a quicker answer, but otherwise I will enquire later today when I get home from work, about 7 hours from now.
I was on the beta test for that router and have it set up as an AP right now (works perfectly well as a router also). My ISP is Virgin Media so the very impressive wireless throughput that the R8500 provides is very welcome.
Use with a compatible Link Aggregation NAS is also very impressive with transfer rates at the full gigabit rate over my very busy LAN, easily hitting a sustained 100Mbytes / second.
- AxeldookOct 28, 2015Aspirant
thanks Andy,
I look forward to hearing from you.
The R8500 router has some impressive specs. Keen to upgrade from my R7000...
- Babylon5Oct 28, 2015NETGEAR Employee Retired
I do have quite a few routers, currently I’m running six concurrently (that’s about 15 different SSIDs), and that includes the R7000 which is one of my favourites.
I have found that the throughput and performance of the R8500 is noticeably higher than the R7000, and as I mentioned above the Link Aggregation feature is a must-have with a compatible NAS.
Sounds good (and a very compressive setup you have too!) My driver for upgrading to the R8500 is signal strength/range
Can you confirm (from your experience) what percentage the difference is between the R7000 and R8500 in turns of improvement. Are we in the reigns of 30%/40% increase in performance would you say?
thanks Andy
