OverworkedFish
Jul 19, 2019Aspirant
AC750 Dual Band WiFi Router Setup issues
Hi I am not sure why netgear make setup so tedious. I downloaded the nighthawk app and connected my phone to the Netgear-20 network and attempted to sign in as admin with the default password, (pas...
- Jul 19, 2019
Only way to reset password is to reset the router. That is done by holding in the reset button located on back of router for about 10 seconds or until the lights start flashing. The the default password of password should work.
For intial setup I prefer using a PC Ethernet connected to router, then putting in the router's IP address, usually 192.168.1.1 into a browser and login and configure from there, rather the the sometimes broken apps.
OverworkedFish
Jul 20, 2019Aspirant
Hi Bill
Thanks for your assistance.
Would appear that my instinct was right - someone had amended the password. I just wish tech stores would reset stuff that customers return before re-selling it.
myersw
Jul 20, 2019Master
Glad you are on the way.
