Goat_hiker's avatar
Goat_hiker
AC750 Internet Port DNS stuck on static numbers
To troubleshoot a connection issue, one internet suggestion was to change DNS to static numbers (8.8.8.8, 8.8.4.4) and try.  Didn't work and I switched back to DHCP. Now I have lots of connection issues and when I check on routerlogin.net-Advanced Home page, the Internet Port page shows DNS still at 8.8.8.8, 8.8.4.4.  I immediately did a factory reset.  In Internet Setup DNS shows DHCP checked but also pri/sec settings of 8.8.8.8, 8.8.4.4 which I can manually reset to blanks but they stubbornly keep reappearing.  Router's DHCP server is "ON".  I wish I knew if any of this matters.  I wish I knew what I'm doing wrong.
  • plemans's avatar
    dhcp server and getting the dns automatically from the ISP are different things.
    DNS should just be a back to switch to.
    A factory reset should clear it out though.
    Are you sure you pushed and held reset for 7-15 seconds while the device was powered on?
    You'd have to fully reinstall the device if you factory reset.
    • Goat_hiker's avatar
      Goat_hiker
      I appreciate you replying!  Yes, I held the reset button until all green LEDs were blinking and I did have to reinstall using routerlogin.  Your comment leads me to believe that this might be unusual, but may not be the cause of any issues I may be having with connectivity - specifically a solar inverter monitoring app and TV streaming accounts - all of which claim no internet when directed to connect to my router's 2.4 service.
      • plemans's avatar
        what modem/gateway are you connected to?
