ThornlessMule
Aug 24, 2021Follower
AC750 model R6020. Can’t connect router to Apartment WiFi.
I live in an apartment that provides WiFi as a part of the rent. It’s a public network and you have to log in to a portal and add the MAC addresses of the devices you want to use. So I’m trying to add...
Aug 24, 2021Guru - Experienced User
If the wifi and the ethernet are provided, its already got a router running. its called a double nat.
What is Double NAT? | Answer | NETGEAR Support
How to fix issues with Double NAT | Answer | NETGEAR Support
