Pdixon6455
Jan 07, 2021Follower
AC750 Network Name Change
I have se-installed a Netgear router and am now using a Comcast service - I need to change the network the extender is attached to?
1 Reply
I usually recommend factory resetting and re-installing extenders when you change routers.
You didn't put what model you have but you can find the manual/install guides at:
netgear.com/support/ then type in the actual model number and it'll take you to the manual/guides.
