haris7
Apr 14, 2023Follower
AC7800 issues
Within the last couple of months my device has consistently told me there is no internet connection on my 2.4 and 5 Ghz wifis. I then need to login to the Genie app and reboot the router and power cy...
michaelkenward
Apr 15, 2023Guru - Experienced User
haris7 wrote:
Within the last couple of months my device has consistently told me there is no internet connection on my 2.4 and 5 Ghz wifis. I then need to login to the Genie app and reboot the router and power cycle it.
Which router are we talking about? AC7800 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
It seems that there is no such thing as AC7800. Maybe you mean R7800.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
