haris7
Apr 14, 2023Follower
AC7800 issues
Within the last couple of months my device has consistently told me there is no internet connection on my 2.4 and 5 Ghz wifis. I then need to login to the Genie app and reboot the router and power cy...
Apr 15, 2023Guru - Experienced User
Are you talking the R7800 or C7800? Because AC7800 is a speed and there isn't a netgear router with that speed.
what modem/gateway is it connected to?
what firmware is on the router?
