jvalerio
Sep 27, 2021Aspirant
Acceso Remoto a router R7000
Tengo un Router R7000 Que enlaza dos redes diferentes. En la punta WAN tengo La direccion 10.193.48.53 En las puntas LAN tengo direcciones del orden de 192.168.1.0 El router tiene la direccion LA...
jvalerio
I've a R700 router that links two different networks
In the WAN side The IP address port is 10.193.48.53
In the LAN side the address are in the order of 192.168.1.0
The router LAN address is 192.168.1.1
From the LAN side I can access the internet hosted in the 10.193.48.0 network
From de LAN side I can access the router by the port 192.168.1.1
From the 10.93.48.0 network I can make ping to the router's WAN port (10.193.48.53) and answer is ok.
I Can't access the router's GUI page via web browser from the 10.193.48.0 network.
Does somebody knows how to do these???
Sep 27, 2021Guru - Experienced User
Usually can't ping the routers web page at 192.168.1.1 from the WAN side.
Do you have Remote Management enabled? This allows access to the routers web page from the WAN side. Otherwise only from the LAN side can you access the routers web page.
