MadMacks
Dec 30, 2021Tutor
Access a AP configured router using Nighthawk? (R6400, R6700v3)
I have a router (R6400) set up to work with a second router (R6700v3) configured as an AP. Nighthawk software sees the AP as an attached device but I can't figure out how to use the Nighthawk applica...
- Dec 30, 2021
Ok. That's what I figured...it would just be nice to do a quick check using the app vs logging in with the IP (which I do all the time). Thx for confirming...
Dec 30, 2021Guru - Experienced User
If your referring to the Nighthawk mobile app, the app only works when the router is in Router mode. No AP mode. You can connect to the AP Mode router using it's IP address and access it's web page there using a web browser on a PC or laptop.
MadMacks
Dec 30, 2021Tutor
