MadMacks's avatar
Dec 30, 2021
Access a AP configured router using Nighthawk? (R6400, R6700v3)
I have a router (R6400) set up to work with a second router (R6700v3) configured as an AP. Nighthawk software sees the AP as an attached device but I can't figure out how to use the Nighthawk applica...
  • MadMacks's avatar
    MadMacks
    Dec 30, 2021
    Ok. That's what I figured...it would just be nice to do a quick check using the app vs logging in with the IP (which I do all the time). Thx for confirming...
