jbenjesus
Aug 04, 2018Guide
Access Control / Attached Devices not showing up
Recently I have been trying to access "Access Control" and "Attached Devices" from any browser when logging in to routerlogin.net. I can access all other tabs and links in routerlogin.net, but for so...
- Aug 05, 2018
jbenjesus wrote:
I have the latest firmware version already.
If you applied the firmware yourself, did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems, especially on the wifi front. Is that how you are connected to the router?
nucloid
Aug 04, 2018Apprentice
the 'connected' list is useless. USELESS. you cannot use it - accessed from any direction - to give you a net map. even the cheapest routers can tell you what devices they route for. I am pissed.
