chunkyks
May 29, 2017Guide
Access Control doesn't Control Access
There are discussions on this forum going back several years [I'll paste a few links at the bottom], but the resolution still seems unclear and dissatisfactory. I went into access controls, and b...
- Dec 17, 2017
I eventually contacted Netgear's security support email, and got the reply that this is as expected. Apparently this is a feature, and not going to be fixed.
Netgear should be ashamed.
JamesGL
Jun 05, 2017NETGEAR Employee Retired
Hi chunkyks,
Access control is working using my R8000. You can try to reset it and manually reconfigure.
