chunkyks
May 29, 2017Guide
Access Control doesn't Control Access
There are discussions on this forum going back several years [I'll paste a few links at the bottom], but the resolution still seems unclear and dissatisfactory. I went into access controls, and b...
- Dec 18, 2017
I eventually contacted Netgear's security support email, and got the reply that this is as expected. Apparently this is a feature, and not going to be fixed.
Netgear should be ashamed.
chunkyks
Sep 28, 2017Guide
Yes. If a device is blocked on my nighthawk, that device is still able to connect to my wifi, other devices on the network are able to communicate with it.
To clarify, expected behaviour [consistent with other manufacturers as well as normal intuition] is that when a mac address is blocked, that it will not be able to connect to the wifi at all.
JamesGL
Oct 17, 2017NETGEAR Employee Retired
Hi chunkyks,
The Access control has different mechanism. It will still be connected to the network but no internet access.
- chunkyksOct 17, 2017Guide
In other words, it doesn't actually block devices from getting on my network. Got it.
Is netgear planning on fixing this so it actually works as expected, like all other vendors devices?
- JamesGLNov 03, 2017NETGEAR Employee Retired
Hi chunkyks,
Let me check on this inquiry and will get back to you.
- chunkyksDec 18, 2017Guide
