MVolker
Feb 01, 2017Aspirant
Access Control filtering not working on Windows 10 machine running NetGenie
Only my Windows 10 machine on which the NetGenie program is loaded, does the Access Control filtering not work at all. My PC is running DHCP ipv4. I have adjusted the filtering level on my computer...
- Mar 01, 2017
Hi MVolker,
Try changing the default to High and change each device filtering level to low and check if it will work.
JamesGL
Feb 03, 2017NETGEAR Employee Retired
Hi MVolker,
1. Did you change the filtering level of this PC to high on the network map?
2. Did you set static DNS or IP on your computer?
JamesGL
Feb 06, 2017NETGEAR Employee Retired
Hi MVolker,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
