MVolker's avatar
MVolker
Access Control filtering not working on Windows 10 machine running NetGenie
Only my Windows 10 machine on which the NetGenie program is loaded, does the Access Control filtering not work at all.  My PC is running DHCP ipv4.  I have adjusted the filtering level on my computer...
  • JamesGL's avatar
    JamesGL
    Mar 01, 2017
    Hi MVolker,
    Try changing the default to High and change each device filtering level to low and check if it will work.
