JZnet
Jun 26, 2021Guide
Access my router from my phone
Hi! Trying to setup my new Frameo wi-fi digital photo frame but the wi-fi shows status of 'scanning'. From all my research and head-scratching, I believe it is due to router security setting of WEP...
- Jun 27, 2021
I successfully changed WEP to WPA2 and also upgraded the router firmware (I'm sure it was very outdated). I had to remove the router from my frameo wi-fi setup and add it back. All is fine now; Frameo is working and we have uploaded photos. Lastly, I am going to investigate if I should change the router mode from 54mbps to 150mbps or 300mbps. Thanks everyone!
JZnet
Jun 27, 2021Guide
Thanks to all for the replies. Since I did not get a resolution, I will restate my issue: I need to login to my WNR2000v3 router to change the security setting from WEP to WPA2. Login attempts by entering my router address into a web browser from either my Samsung Galaxy S9 phone (which is connected to and is using the router) and my HP PC provide the login screen but are unsuccessful with '401 unauthorized, access to this resource is denied, your client has not supplied the correct authentication'. I am entering 'admin' for username and my router password. Why is this login not working? Thanks again, John.
