JZnet
Jun 26, 2021Guide
Access my router from my phone
Hi! Trying to setup my new Frameo wi-fi digital photo frame but the wi-fi shows status of 'scanning'. From all my research and head-scratching, I believe it is due to router security setting of WEP...
- Jun 27, 2021
I successfully changed WEP to WPA2 and also upgraded the router firmware (I'm sure it was very outdated). I had to remove the router from my frameo wi-fi setup and add it back. All is fine now; Frameo is working and we have uploaded photos. Lastly, I am going to investigate if I should change the router mode from 54mbps to 150mbps or 300mbps. Thanks everyone!
JZnet
Jun 27, 2021Guide
Never mind! I got logged in. Just realized I was using my Wi-Fi password, which is different than my router password. Thanks for all input, and sorry for heading down the wrong path. John.
michaelkenward
Jun 27, 2021Guru - Experienced User
That's good.You could have cut to the chase by reading the manual and following the instructions you were given earlier.
You didn't get the answers you wanted because you were asking an impossible question that has no answer.
I step in now only to add another caution.
I need to login to my WNR2000v3 router to change the security setting from WEP to WPA2.
Do not waste time trying to do that now that you have found your way into the router.
Again, reading the manual will explain why you are barking up the wrong tree.
- antinodeJun 27, 2021Guru
> [...] Just realized I was using my Wi-Fi password, which is different
> than my router password. [...]> [...] Look for "Types of Logins" [...]
> into the router."waste time"? Because wireless-network security is unimportant?
> WPA2 is safer than WEP.
A Web search for terms like
WEP WPA
should find any number of recommendations to avoid WEP these days. One
example:https://www.lifewire.com/what-are-wep-wpa-and-wpa2-which-is-best-2377353
As always, beware of free advice from over-confident "experts".
- JZnetJun 27, 2021Guide
- michaelkenwardJun 27, 2021Guru - Experienced User
Did you read the bit about WEP in the manual? (Page 28)
"WEP encryption is available only when the Mode setting is Up to 54 Mbps."
It isn't as clear as it could be – it is a Netgear manual after all – but one interpretation of that could be that moving to 150mbps or 300mbps would disable WEP encryption.
