w0rM's avatar
w0rM
Accessing a Readyshare Drive Without Router
I had a Nighthawk X6 which I just got rid of. While it was still in service at my house, I had a readshare drive going. Now that I've sold it, is there anyway to get to the files on my USB drive that I was using or am I out of luck on recovering them (without buying another Netgear router)?
  • > [...] is there anyway to get to the files on my USB drive [...]
       I'd try connecting it to a computer which is compatible with the file
    system on that (unspecified) "USB drive".
       Netgear didn't invent some new and exotic file storage system
    especially for this.
    • w0rM's avatar
      w0rM
      It's a WD Easystore. I don't believe the model matters. I wasn't suggesting anything is broken. I'm trying to understand how to get files off of a USB device that was used as any readyshare drive. I'm fairly certain the issue has nothing to do with the model of the drive.
      That said, the first thing I did was connect it to a Windows 10 machine and a Macbook Pro. It powers up but whatever file system it is, neither Windows or a Mac can read it. That was the purpose of my question. Sorry I wasn't more clear. I assumed most people would realize I didn't just guess that it wouldn't work and that I had actually tried to plug it into a computer before creating an account to ask for help.
      So, if Netgear isn't using a proprietary file system of some kind, am I to assume it's ext3 or maybe ext4?
      • > [...] I assumed [...]
           I've wasted too much of my life doing that.  And I learned something
        from watching "Desk Set" (1957).
        > [...] am I to assume it's ext3 or maybe ext4?
           You have my permission to assume whatever you'd like.  I know nothing
        about how that volume was configured (or on what), so I know nothing
        except that a User Manual for a typical Netgear router with USB storage
        support includes a section with a title like "USB device requirements",
        where I'd expect to find a list of supported file systems.
           Visit http://netgear.com/support , put in your (actual) model number
        -- Hint: "Nighthawk X6" is not it.  Look for "Model" on the product
        label. -- and look for Documentation.  Get the User Manual (at least).
        Read.  Look for "USB".
