HelpfulDad
Feb 28, 2021Aspirant
Accessing MB8600 Configuration page through r7000
Can anyone give me the secret sauce that will enable me to reach a Motorola MB8600 login page of the modem attached on my WAN port on the router from a device on the r7000 LAN? R7000 is configure...
antinode
Mar 02, 2021Guru
> It comes out of the box as /24 and as I said, didn't work as it was
> either.
You said that. But, regarding "didn't work", see "useful problem
description [...]", above.
"My car wasn't working. I filled the fuel tank with soapy water."
"Drain the water from fuel tank, dry it, and add proper fuel."
"But it didn't work that way."
"I know nothing about your original problem."
"I'm looking for someone who has seen this before and can help."
"seen" _what_, exactly?
HelpfulDad
Mar 12, 2021Aspirant
then don't answer. It's not like you've been helpful anyway.
- antinodeMar 12, 2021Guru
> then don't answer. [...]
Same to you. I was still waiting for a useful description of the
problem _before_ you decided to fix everything by changing a subnet mask
so that nothing could be expected to work.> [...] It's not like you've been helpful anyway.
If you expect "helpful" without answering basic questions, then you
might benefit from the results of a Web search for:"life is like a sewer"
