flimps1's avatar
flimps1
Tutor
Sep 16, 2024
Accessing my AC1900 R7000
Hello, I would like to put my router into AP and switch mode (no idea how to do it). But to start it, I cannot connect to the router. By using the app, it tells me the router is disconnected, by using...
  • michaelkenward's avatar
    michaelkenward
    Sep 16, 2024
    When you are following the instructions from plemans you can make life easier for future management by fixing the IP address on your access point. Then, whenever you want to get into the GUI you just aim a browser at that address.
    Read how to do that in the KnowledgeBase piece:
    How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
    Check point 5, "Select AP Mode" and note that you don't need "advanced network experience", just the ability to use a browser.
    Just another user with time on their hands.
