dmuir
Jun 08, 2018Aspirant
Accessing routerlogi.net/com when router is in bridge mode
I have two R6400v2 routers, one set up in bridge mode so non-wifi hardware can be used in another room. With the recent reports of malware aimed at routers, I follow the recommendation to update firm...
- Jun 08, 2018
> [...] The router in bridge mode, though, returns the following message
When you do what, exactly? That message does not come from your
R6400v2-as-bridge. You were (your web browser was) talking to a Netgear
server which returns that misleading/useless error page:
https://community.netgear.com/t5/x/x/m-p/1365830
> I have searched and found the "Can't access
> routerlogin.net/routerlogin.com or default IP" thread, [...]
With my weak psychic powers, I don't know which "the [...] thread"
that might be. An actual link would be more helpful.
> [...] which would have me factory reset the bridged router, then
> disconnect my existing network from the modem, connect the formerly
> bridged router to the modem long enough to update firmware, then
> reconnect everything and go through the bridge process all over again.
It's not quite that bad. You don't need to connect the reset router
to your modem to do the update. You could download the firmware kit to
your computer, reset the bridged router, connect (only) your computer to
the now-in-router-mode router, update its firmware manually (from the
downloaded kit contents), and then do the bridge configuration again.
The router-to-be-updated does not need to be connected to the Internet
for that, only to your computer (with the downloaded firmware kit).
> Do I NEED to update firmware on the bridge router, [...]
Perhaps not. I don't know how susceptible it would be in that mode.
It's not as if the firmware Release Notes would tell you anything useful
about this. I'd probably do it.
> [...] is it really the case that the only way out of bridge mode is a
> complete factory reset? Any other solution?
If the R6400v2-as-bridge is completely transparent, then it may not
be possible to talk to it in that mode. If it appears as a device on
your LAN (in an Attached Devices report on the main R6400v2-as-router,
for example), then you should be able to point your web browser at its
IP address (instead of trying to use any of those names like
"[www.]routerlogin.net", which are guaranteed to fail). If it's truly
invisible in bridge mode, then setting it back to non-bridge mode would
seem to be a requirement.
> I'd really like to hear from a moderator.
I can't help you with that.
antinode
Jun 08, 2018Guru
- antinodeJun 10, 2018Guru
> be possible to talk to it in that mode. [...]
For those in suspense, I've now had a chance to try this using an
R7000 (V1.0.7.12_1.2.5 -- yes, it's old). The router-as-bridge does get
its own LAN IP address, it does appear in the main router's BASIC >
Attached Devices report, and its ADVANCED > Administration > Router
Update page gives every indication of a willingness to perform an
update while in Bridge Mode.- dmuirJun 10, 2018Aspirant
Thanks for posting this. I clicked on "solved" first and it seemed like I could not then post a reply.
Yes, the solution worked perfectly. I found the bridged R6400 router in the main R6400 router's Attached Devices list, logged into the IP address listed, and updated my firmware without any problem.
Easy once you know how but it sure wasn't intuitively obvious to me. Thanks for the clear and prompt advice.
Netgear documentation seems to go silent quickly when it comes to
alternative operational modes (access point, bridge, ...). The user
interface lacks a few things, too, I thought. Like, when setting Bridge
Mode, displaying a list of the gizmo's own SSIDs rather than any
external ones to which you might wish to connect.
A few well-written KB articles might have some value for these cases.
And, of course, the generally useless "[www.]routerlogin.{com|net}"
error pages could mention that those names are hopeless when trying to
contact a router whose DNS server is sure to be disabled or ignored.
I won't be holding my breath.
Glad to hear that you got it working. Marking as "Solved!" was a
good start, but there were some unresolved mysteries. I got an R7000
(Ebay, cheap) today, which let me check the details rather than guess.
