dmuir's avatar
dmuir
Accessing routerlogi.net/com when router is in bridge mode
I have two R6400v2 routers, one set up in bridge mode so non-wifi hardware can be used in another room. With the recent reports of malware aimed at routers, I follow the recommendation to update firm...
  • antinode's avatar
    Jun 08, 2018
    > [...] The router in bridge mode, though, returns the following message
       When you do what, exactly?  That message does not come from your
    R6400v2-as-bridge.  You were (your web browser was) talking to a Netgear
    server which returns that misleading/useless error page:
          https://community.netgear.com/t5/x/x/m-p/1365830
    > I have searched and found the "Can't access
    > routerlogin.net/routerlogin.com or default IP" thread, [...]
       With my weak psychic powers, I don't know which "the [...] thread"
    that might be.  An actual link would be more helpful.
    > [...] which would have me factory reset the bridged router, then
    > disconnect my existing network from the modem, connect the formerly
    > bridged router to the modem long enough to update firmware, then
    > reconnect everything and go through the bridge process all over again.
       It's not quite that bad.  You don't need to connect the reset router
    to your modem to do the update.  You could download the firmware kit to
    your computer, reset the bridged router, connect (only) your computer to
    the now-in-router-mode router, update its firmware manually (from the
    downloaded kit contents), and then do the bridge configuration again.
    The router-to-be-updated does not need to be connected to the Internet
    for that, only to your computer (with the downloaded firmware kit).
    > Do I NEED to update firmware on the bridge router, [...]
       Perhaps not.  I don't know how susceptible it would be in that mode.
    It's not as if the firmware Release Notes would tell you anything useful
    about this.  I'd probably do it.
    > [...] is it really the case that the only way out of bridge mode is a
    > complete factory reset? Any other solution?
       If the R6400v2-as-bridge is completely transparent, then it may not
    be possible to talk to it in that mode.  If it appears as a device on
    your LAN (in an Attached Devices report on the main R6400v2-as-router,
    for example), then you should be able to point your web browser at its
    IP address (instead of trying to use any of those names like
    "[www.]routerlogin.net", which are guaranteed to fail).  If it's truly
    invisible in bridge mode, then setting it back to non-bridge mode would
    seem to be a requirement.
    > I'd really like to hear from a moderator.
       I can't help you with that.
