Jsard
Jun 13, 2022Tutor
Accidentally clicked change to static ip and now everything erased and cant connect to the internet.
Like it says..accidentally selected static it it erased all the info from the original original and now I can't connect to the Internet please helplease help before my wife and kids beat me.
- Jun 14, 2022Got ahold of my isp and they were able to erase the 2 IP's that were showing. Reset my Netgear orbi router and now it works.
microchip8
Jun 13, 2022Master
Do a factory reset. There's a Reset button at the back of the router. Press it in for 7-10 seconds, then release. You'll have to set up again everything. If you have a backup of your settings, you can safely load it and bypass setting from scratch
- JsardJun 13, 2022TutorI reset it and it gets all the way to the spot that says checking cable ✔️.. then checking internet and icon spins for a while then it says no internet try again? And I tried again but same result.
