pgurlea's avatar
pgurlea
Tutor
Apr 09, 2021
According to Comcast, AC1600 all in one router (C6250) not compatible with Comcast 4K TV BOX, XG1V4
Hi Folks, Looking for some ideas or recommendations. I just picked up a Samsung 4K TV. Comcast, is telling me that my all in one router AC1600 (C6250) is not not compatible with Comcast 4K Wi-Fi TV ...
  • plemans's avatar
    Apr 09, 2021
    Are you connecting your XG1V4 via wireless? or wired?
    And if via wireless are you trying to connect it ot the 2.4ghz or 5ghz?
    the XG1V4 shouldn't care what modem it is unless it can't provided the needed speeds.
