Kray6102
Mar 07, 2022Follower
AD7200 WiFi Inoperable, finicky LAN Connection
Hello everyone, I've got an issue with my router that Ican't seem to solve and I am confident it is a hardware issue at this point. Here's the details: Model: R9000 | Nighthawk X10 AD7200 Sma...
Mar 08, 2022Guru - Experienced User
What is the brand and model Switch you have connected?
What CAT# LAN cables are you using? CAT6 is recommended.
