BrunoMartins
Aug 23, 2021Follower
Add an extender to the router with the Nighthawk app
I just installed the RAX50/AX5400 router with the Nighthawk app but have no idea how to instal the extender as I cant figure it out how to add a second device into the Nighthawk app. Need some help ...
Aug 23, 2021Guru - Experienced User
https://www.netgear.com/support/product/EX8000.aspx
There's install guides here. You can use wps or the installation wizard to install it.
