JimmieNordberg
Dec 10, 2022Aspirant
Add new Firmwire för R7000 now the 5ghz do not work
And thats problem because the 2.4 is slower and the kids want to play online.
Dec 10, 2022Guru - Experienced User
Not much to go on.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What devices are you connecting?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- JimmieNordbergDec 10, 2022Aspirant
V1.0.11.136_10.2.120
DIdn´t change anything and has been working before, the only thing that did´nt work before was connect a chromecast, thats why I did the update.
Use Auto and 44.
Should I try "Smart connect"
