Jman2000's avatar
Jman2000
Follower
Jun 25, 2021
Added switch to network but not working
My internet provider has given me a Homehub 3000 MODEM ROUTER. Has 4 ports and 1 WAN PORT.
1 OF 4 ports is connected to my netgear nighthawk R7200 AC2100 smart wifi router. This also has 4 ports and 1WAN PORT. This is setup as a wifi router (primary)
1of 4 ports goes to another part of the house to a Netgear Nighthawk R7000 AC1900 Smart wifi router. This is setup as an AP.
I was running out of ports so I bought a Netgear prosafe 24 port gigabit switch JGS5524, PLUGGED it into the 2nd port of the primary netgear router but it's not working. Yet if I plug anything directly into the router it works.
Any idea as to the possible problem? Thanks
1 Reply
  • > My internet provider has given me a Homehub 3000 MODEM ROUTER. [...]
       Is it configured as a modem+router, or as a modem only?
    > [...] 1 OF 4 ports is connected to my netgear nighthawk R7200 AC2100
    > smart wifi router. [...]
       So, is that a modem-only with the R7200 as a router (ok), or a
    modem+router with the R7200 as a router (less than ok)?
    > [...] I bought a Netgear prosafe 24 port gigabit switch JGS5524, [...]
       "JGS524"?  Plain-old "JGS524[v1]", or some newer/fancier variation?
    Look for "Model" on the product label.
    > Model: JGS524v2|ProSAFE 24 Port Gigabit Rackmount Switch
       Which/what is it, really?
    > [...] PLUGGED it into the 2nd port of the primary netgear router [...]
       Do you mean that you ran an Ethernet cable from the R7200 LAN port 2
    to some port on the JGS524?
    > [...] but it's not working.
       Which kind of "not working"?
       A vague description of what some device does _not_ do is less useful
    than a clear description of what _does_ happen.
       "not working" is not a useful problem description. It does not say
    what you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       Have you tested/swapped the Ethernet cable(s)?
    > Any idea as to the possible problem? [...]
       Without knowing what the LED indicators indicate?  Not with my weak
    psychic powers.
       Visit http://netgear.com/support , put in your model number(s), and
    look for Documentation.  Get the User Manual (at least).  Read.  Look
    for the LED descriptions and "Troubleshoot".
