kikipyz
Dec 06, 2022Follower
Adding 2.4 channel 11 on NightHawk model R6700v3
I have a nighthawk Model R6700v3 operating at 5 GHz. I need to ad a 2.4 GHz channel 11 to connect my new HP Desk Jet 3755 printer. How do I do that.
Dec 06, 2022Guru - Experienced User
The R6700 is a dual band router. It should already have 2.4ghz enabled.
you can log in through the browser and check it.
You might just be using smart connect that combines the 2.4ghz/5ghz into 1 ssid
You can change the channel to 11 with Smart Connect enabled.
microchip8
Dec 08, 2022Master
Go to http://routerlogin.net or http://192.168.1.1 with a browser. See if you have Smart Connect enabled. If so, disable it. Then set the channel you want for the 2.4 GHz band.
