ddubbed
Nov 07, 2020Follower
adding additional adapters to powerline wifi
i would like to know how to add an additinal adapter to my excisting wifi systems. i also would like to know if i add another adapter which model of powerline adapter would be compatiable with what ...
Nov 08, 2020Guru - Experienced User
You can add addional powerline devices. Here's how
https://kb.netgear.com/22165/Adding-a-powerline-adapter-to-an-existing-powerline-network
You can even mix/match between companies provided they use the same powerline standards. Just keep in mind that it'll function at the lowest devices speeds though.
