Benjamin473
Apr 08, 2022Aspirant
Adding external antenna to R7000 Router
Hi, all I would like to add an external antenna (https://www.amazon.com/dp/B09DKZ7RNH) to my Nighthawk R7000/AC1900 can you advise as to which port I should connect it to? There's three antenna ports...
Benjamin473
I'm aware of that, but what I am seeking clarity on is which port can I use for the external antenna. I'm also aware that you have to remove two antennas once you connect the external, but the question is which port do I connect the external. I've seen else where it says furthest to the left while some says furthest to the right
Apr 08, 2022Guru - Experienced User
You can try plugging in and see. All 3 ports gets same data flow, there isn't a difference per port.
- Benjamin473Apr 08, 2022Aspirant
ok will do
