The-real-Jimbo
Oct 24, 2021Aspirant
adding older wifi router to current nighthawk app account
I HAVE A NETGEAR R7900P MODEM AND AC4000 WIFI ROUTER (R8000P) THE MODEM CAN BE ACCESSED WITH THE NIGHTHAWK APP HOWEVER THE OLDER WIFI ROUTER CANNOT BE ACCESSED BECAUSE IT IS REGISTERED UNDER AN OLDER...
Oct 24, 2021Guru - Experienced User
So the R7900P is not a modem, it's also a router.
Have you factory reset the 7900 series router and setup from scratch using a wired PC and web browser. After it's setup, be sure your mobile device with the NH app is connected to the 7900 series wifi and the app should connect too it.
No need to Yell please. We can hear you fine.
The-real-Jimbo
Lol sorry about that I started typing away and didnât pay attention at the caps lock being on.. đ
