Mrlock1
May 16, 2021Follower
Adding satellite
Nighthawk mesh ax1800 mk63 can you add more than 3 satellites
May 16, 2021Guru - Experienced User
I've read you can add more but the performance drops after the 2-3 satellites because its only a dual band system.
If you're using a wired backhaul, I'd imagine you can use significantly more like the orbi system
