StCroixTech
Mar 30, 2022Follower
Adding VLAN with Centurylink Internet Service - What NetGear Router and Suggestions on Configuration
I currently have CenturyLink Business Class Service with a Zyxel C3000Z Modem Router. I want to create two VLANs on a Netgear GS324TP S350 Series 24-Port Gigabit Ethernet PoE+ Smart Managed Pro Swit...
michaelkenward
Mar 31, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Smart / Plus / Click Switches - NETGEAR Communities
I will see that your message gets moved.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
