Albert_one
Jan 02, 2022Aspirant
Additional access point
I want to install an additional Wi-Fi router, I have actually only one, the model is PLW1000 v2. This model is no more sold, which model can I buy that is compatible with my router?
- Jan 03, 2022
You can use models from netgear or other providers when you're using powerline. The powerline connection follows a powerline standard and provided the manufacturer follows that standard, they're interoperable.
Albert_one
I bought PLW1000 access point with one Wi-Fi repeater in 2019 and now I want to add just one repeater. As I don’t want to change everything because I cannot find this model again in commerce, I would like to add a repeater of a different model that is compatible with plw1000
Jan 03, 2022Guru - Experienced User
- Albert_oneJan 03, 2022AspirantMany thanks I will follow your suggestion
