remington_rand
Sep 01, 2021Initiate
Additional router to connect to MS80 mesh system
I have a mesh system with the Nighthawk MR80 as the base router, with 2 satellites. I'm unable to beam the wifi signal to my home theater room. The wall is made of kryptonite. Best solution is for me...
- Sep 02, 2021
You don't need another router.
You can simply hardwire in one of the MS80 satellites. they have an ethernet port and support wired backhaul.
Sep 02, 2021Guru - Experienced User
remington_rand
Sep 02, 2021Initiate
Fantasic! I was thinking that Ethernet port was output only. Simple solution is the best. Thank you for your help.
- plemansSep 02, 2021Guru - Experienced User
Hope it works well for you!
