JerryB69
Oct 10, 2016Aspirant
Address reservation table
In my router setup..Advanced...lan setup, I have a checkmark before "use router as a d??? server" Next is a table titled "ADDRESS RESERVATION"...I have 19 entries in this table and they don't seem t...
- Retired_MemberOct 10, 2016
JerryB69 wrote:
In my router setup..Advanced...lan setup, I have a checkmark before "use router as a d??? server" DHCP
Next is a table titled "ADDRESS RESERVATION"...I have 19 entries in this table and they don't seem to change. They don't change, they appear as they connect to router, for those who use address reservations this saves them the time and effort of adding all the data. If you want to add a device you simply check it and edit last XXX of IP and then hit apply it then drops down to reservation list.
Are these entries Static or reserved IP's??? reserved ONCE you add to address reservations
Thanks for your reply. You're welcome!
PS..I never manually setup these addresses..they are just in this table. YES THAT is correct!
my comments are in red encase it's not obvious
Also my list is full with 22 reserved devices and my TABLE is empty because everything attached is reserved, don't get hung up over what list shows first meaning address reservation or address reservations TABLE it will be different depending on how big your network is.
JerryB69
Are the addresses in this "RESERVATION TABLE" already RESERVED or must I click and move them somplace else (ie you reply.) in order to make them static or reserved ???..
