Silverfox67
Apr 16, 2017Aspirant
Adjust router to accept new 1 gig isp or gigaone from cableone
Hi, I have a question for you. I have a Netgear Nighthawk AC3200 R8000. I have been using Cable One at 100 mhz. I just upgrade to GigaOne but the fastest speed I can get is about 500 mhz. I also upgr...
- Apr 18, 2017
Thanks to All for your Help and Support. The problem is fixed.
1. I did a factory reset of the router. When I tried to do the install the router stated that there was another router between the modem and the netgear router?
2. When the tech did the install of the Arris DG3270 he stated that it was a modem/router and that he would have to disable the router.
3. I called CableOne support and they said it looks like the router was disabled but they could not explain the error message. Support then put the modem in the bridge mode and did an additional disable of the router and rebooted the modem twice.
4. So between the factory reset and the changing of the Arris DG3270 to the bridge mode and re-disabling of the router the problem is solved.
I now have 935 Mbps down and 53 Mbps up. Nice!
I am interested if there is going to be a firmware up grade of the Netgear CM700? If anyone hears anything, please forward it.
I hope that this will help anyone in the future upgrading to CableOne and GigaOne.
Thanks again for all your time and help. I really appreciate it.
netwrks
Apr 16, 2017Master
I have been using Cable One at 100 mhz. I just upgrade to GigaOne but the fastest speed I can get is about 500 mhz. I suspect you are talking about 100 Mbps and 500 Mbps. Since the CM700 is a docsis 3.0 modem, that may be the reason you cannot achieve gigabit speeds. Either way, check with you ISP to see what modem they sanction for gigabit. Not sure the R8000 can support gigabit either. Best way to test that you are getting what you are paying for, is to connect a laptop with a 1000Mbps NIC card and test your connection. I'm sure others will chime in.
William10a
Apr 16, 2017Master
The r8000 says it has 1gb lan ports as you said they will need a computer with a 1gb lan port connected direct to the modem to know their internet connection speed. I have found that the speed shown by the web site you use can be very different from one to another using the same connection on your network
