JLRowan
Jun 01, 2020Initiate
Admin login site is not secure
I logged in to my router as admin so I could update the password, but the connection is not secure. Is this common, or is there something I can do to make it secure? Thank you.
- Jun 02, 2020
Thank you! I appreciate the responses and explanation!
antinode
Jun 01, 2020Guru
It's common to get complaints from a modern web browser when you use
the router's management web site, because the browser is worried about
your sending some user credentials over an unencrypted/insecure link
("http://" instead of "https://"). The easy thing to do is ignore the
warning, and proceed. Presumably, you're talking to your own gizmo on
your own LAN. If someone can overlisten to that local traffic, then
you're already in big trouble.
> its normal because you're on your local network. you're not "online".
It's not "normal because you're on your local network." It's
(probably) _harmless_ because you're on your local network. It's
"normal" because a typical Netgear consumer-grade router uses HTTP, not
HTTPS, for access to its management web site.
JLRowan
Jun 02, 2020Initiate
