Boricua63
Nov 07, 2019Tutor
Admin login times out
Cannot access router admin page from my wireless laptop. Tried the app and even Genie app with no luck. I don't recall what has changed that would not allow me access it. URL - https://www.routerl...
- Nov 07, 2019
Instead of using the URL have you tried using the IP address of the router in a browser? Normally the address would be 192.168.1.1 or 192.168.0.1.
antinode
Nov 07, 2019Guru
> Curious as to why the URL would not work.
I'm (still) curious as to exactly which URL(s) you're using.
> [...] https://www.routerlogin.net [...]
That one could fail because the router's management web site can use
only "http://", not "https://". But you claimed:
> Have used this same URL in the past with no issues.
So what you're doing differently is not entirely clear. As usual,
details can matter.
> I did try with the IP address 192.168.1.1 and was able to access the
> admin site.
If you specified neither scheme, "http://" or "https://", explicitly,
then your (unspecified) web browser might first have tried "https://",
but reverted to "http://" if the "s" one failed.
> The app I'm using [...]
I stick with a web browser, and avoid Netgear apps, so I have no
information on that failure.
Boricua63
Nov 07, 2019Tutor
I did use the http:// URL and its working with the Edge browser. Chrome is the problem. I will check the settings there.
I will open a separate ticket on the iOS app issues. All good here. Thanks for your responses.
