careal71
Dec 24, 2020Aspirant
Admin Login website
Cannot access the admin password reset links provided. Assistance requested. Links: https://www.routerlogin.net/ https://www.routerlogin.com/
schumaku
Jan 03, 2021Guru - Experienced User
Would be interesting from where this -wrong- or at least misleading information is coming from.
A possible source is the Netgear KB entry How do I recover my NETGEAR admin password using the password recovery feature? Let the community us know if you find more wrong references please.
Taking the fact that most routers (including your R6080) this article is supposed to apply to are -not- supporting https please kindly try http://www.routerlogin.net/ or http://www.routerlogin.com/ instead.
Said that, there is absolutely nothing wrong with antinode well meant advise to check the fine documentation.
Please be aware we're just Netgear users spending some spare time to assist in the community. We're neither paid nor sponsored in any way.
Christian_R Please take care that this KB mess, count in the video referred using 10.0.0.1 IP address, and at least these two KB entries How do I recover my NETGEAR admin password using the password recovery feature? | Answer | NETGEAR Support and How do I reset the admin password on my NETGEAR router? | Answer | NETGEAR Support are fixed/merged/corrected. Thank you! It's ridiculous how careless Netgear does handle their customers...
careal71
Jan 03, 2021Aspirant
Thanks for the response. I did not mean to be rude to a previous response but it came across as disrespectful to me (as a novice to this). I am finding Netgear platform not easy to navigate (ie posting screenshots). Not sure why it is an issue Best.
- antinodeJan 03, 2021Guru
> screenshots). Not sure why it is an issue Best.The non-psychics in your audience might find it difficult to guess
what this "issue" might be. See "not a useful problem description
[...]", above. Which part of "actual" was unclear?You now have two people offering the same suggestion about the form
of the URL which you're using. Have you considered trying it?> [...] it came across as disrespectful to me (as a novice to this).
> [...]I didn't like your lack of responsiveness, either. As for being "a
novice", the less you know, the more important accurate, detailed,
precise descriptions become. (And the less value your analysis may
have.) What you did, and what happened when you did it, are what
matter. Non-descriptive conclusions like "I am finding" often convey
little or no useful information. (In this case, "no".)- schumakuJan 03, 2021Guru - Experienced User
careal71 don't worry, we know how the various browsers default messages are looking.
Have managed to regain access to your router in the meantime?
- careal71Jan 04, 2021AspirantI had to redo the process with the provided link the community provided. It finally worked (had to reset again). Thanks.
