careal71
Dec 24, 2020Aspirant
Admin Login website
Cannot access the admin password reset links provided. Assistance requested. Links: https://www.routerlogin.net/ https://www.routerlogin.com/
antinode
Jan 03, 2021Guru
> I am finding Netgear platform not easy to navigate (ie posting
> screenshots). Not sure why it is an issue Best.
The non-psychics in your audience might find it difficult to guess
what this "issue" might be. See "not a useful problem description
[...]", above. Which part of "actual" was unclear?
You now have two people offering the same suggestion about the form
of the URL which you're using. Have you considered trying it?
> [...] it came across as disrespectful to me (as a novice to this).
I didn't like your lack of responsiveness, either. As for being "a
novice", the less you know, the more important accurate, detailed,
precise descriptions become. (And the less value your analysis may
have.) What you did, and what happened when you did it, are what
matter. Non-descriptive conclusions like "I am finding" often convey
little or no useful information. (In this case, "no".)
schumaku
Jan 03, 2021Guru - Experienced User
careal71 don't worry, we know how the various browsers default messages are looking.
Have managed to regain access to your router in the meantime?
- careal71Jan 04, 2021AspirantI had to redo the process with the provided link the community provided. It finally worked (had to reset again). Thanks.
