twfeeney
Sep 16, 2021Aspirant
admin password question model R6700-100NAS
Where would I find the Admin password? I can't move forward on set-up with out it.
Sep 16, 2021Guru - Experienced User
Installation Guide or User manual PDF file online.
Usually default is 'password'
- twfeeneySep 16, 2021Aspirant
password doesn't work. Do I need to reset somehow?
- plemansSep 16, 2021Guru - Experienced User
make sure about lower case. Its all lower case
login: admin
password: password
all lower case.
If you changed it from the defaults, then you'd need to use the password recovery feature.
If you didn't set that up (it still asks the questions) or don't know the answers, then you'd need to factory reset to get back to the defaults.
