Poppa00420
Sep 07, 2021Follower
Admin password reset Nighthawk AX6000 cax80
I purchased a used modem router. Works great but can’t complete setup on app because I can’t reset admin password. I pressed reset button on rear for 30s. Still says (admin/password) are not correct. ...
Sep 07, 2021Guru - Experienced User
have you tried logging in through the browser and not the app?
default login is: admin
default password: password
try using the browser.
also, when you reset, did you push and hold while the device was powered on?
