jmb-555
Aug 06, 2023Aspirant
Admin password wont save Nighthawk R8000 Router
I have a Nighthawk X6 R8000 router and I am unable to change the default password when in the configuration menu. I hit the "apply" button and everything seems to go ok but the password never saves. ...
michaelkenward
Aug 07, 2023Guru - Experienced User
jmb-555 wrote:
I'm assuming the brings the firmware back to factory settings and the problem immediately went away. Could anyone provide an explanation for this? It seems like it would definitely be something to be concerned about.
You have carried out one of the basic troubleshooting moves. A reset is recommended whenever someone has a problem with a router.
A reset will erase any corrupt settings in the firmware.
When you have a configuration that works for you. it helps to save the settings.
Then you can restore them if you hit problems in future.
